So will Raid 0 TRIM work on my Asus Sabertooth Z77?
Asus is using the Enterprise level drivers, which trim does not work with
It actually works on the P67s too if you can get the latest Option ROM flashed. The Z77 OROM flash works on the P67s... thus allowing TRIM in R0. Gotta find a custom BIOS though. Many have done it successfully.
The 11.x OROM's for Z77 provide backward compatibility for earlier series chipsets but not RAID0 trim support for them, at least none that I have seen.It actually works on the P67s too if you can get the latest Option ROM flashed. The Z77 OROM flash works on the P67s... thus allowing TRIM in R0. Gotta find a custom BIOS though. Many have done it successfully.
