Does this need any improvements
RKBET
MY Current computer
CM 690 Nvidia Edition
ASUS M4N82 Deluxe
AMD Phenom II X4 940 Overclock to 3.6GHz
CORSAIR DOMINATOR 3x 2GB DDR2 1066 PC8500 RAM
Western Digital Caviar Black 640GB Hard Drive
2x XFX GTX 260 896MB SLI Video Cards
Creative Sound Blaster X-Fi Titanium Fatal1ty Professional
SAMSUNG 22X DVD Burner
CORSAIR CMPSU-850TX 850W Power Supply
Windows 7 Ultimate x64
Do I or you have to update anything.
Depends on what you want to do with it. Answer the following for us:
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license?
forgot about the questions
All round
doent matter much
Miami, Florida
anything thats upgradable
the same from my first post.
yes
22" now 24" later
whenever
to use up to 3 pci-e slots
nnnnnnnnnnnnnnnnnnnnnn yes
MY Current computer
ASUS M4N82 Deluxe
That's your current system? Is it lacking performance in anything you do? If not, then leave it as is. If its lacking, when?
One question, though... you have 3x2GB of RAM on a dual channel board?
Save some money by getting windows 7 professional 64bit. the ONLY improvements with ultimate is that you can use lots of different languages(27 I think... might be a little off) and something called: BitLocker - Helps protect data on your PC and portable storage devices against loss or theft
theres 3 because my heatsink on my cpu is covering 1 slot and the rams are tall.
Ok, you still haven't answered enginurd's other question: Is it lacking performance in anything you do? If not, then leave it as is. If its lacking, when/where?
Windows 7 Ultimate has support for 35 different languages, and BitLocker is simply drive encryption software similar to the freeware-based TrueCrypt. It also has Windows XP Mode (with a free copy of Virtual PC, which you would have to download) and Remote Desktop connection, features that are also part of Windows 7 Professional. You can replicate the effects of Windows XP Mode and BitLocker on Windows 7 Home Premium using freeware alternatives (Virtual PC 2005 and TrueCrypt, respectively), so unless you need 35-language support and/or remote desktop access, stick with Windows 7 Home Premium.
