Punisher11
- Oct 18, 2007
EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
Model #: 122-CK-NF68-A1
Item #: N82E16813188013
MSI NX8800Ultra-T2D768E-HD-OC GeForce 8800Ultra 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Model #: 8800UltraT2D768EHDOC
Item #: N82E16814127288
PC Power & Cooling Silencer 610 EPS12V EPS12V 610W Continuous @ 40°C Power Supply - Retail
Model #: Silencer 610 EPS12V
Item #: N82E16817703005
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Model #: BX80562Q6600
Item #: N82E16819115017
CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5DHX - Retail
Model #: TWIN2X4096-6400C5DHX
Item #: N82E16820145176
Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Model #: WD1500AHFD
Item #: N82E16822136011
I chose this cause its $184 @ newegg
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
Model #: SH-S203B
Item #: N82E16827151153
Arctic Silver 5 Thermal Compound - OEM
Model #: ARCTIC SILVER 5
Item #: N82E16835100007
ASUS V-60 92mm Vapo Bearing CPU Cooler - Retail
Model #: V-60
am I missing anything? im bouncing around a cople of cases in my head, but i wanted to make sure i had the core of the hardware set. this will be used for gaming, and if it fits in the right box, lan party
i plan to run it on at least a 20in (or possibly larger depending on black friday
) lcd monitor.
Im concerned if the memory works with the mobo.
i also have roughly $2500 spending limit. i already have an OS so that isnt an issue.
TIA.
Model #: WD1500AHFD
Model #: SH-S203B
Model #: V-60
TIA.
