Bleedblue12345
- Nov 1, 2004
So currently I have a Thermaltake Soprano DX Case and a Tuniq Tower and they are peices of junk. My Q6600 loads at ~ 75-80C under max load and I have reseated/repasted over 5 times now. So I am sick of my high temps and plan to go all out with my air cooling, and I was just wondering what you guys thought of this setup.... This setup will also be used when I go Core i7 or whatever later this year/early next...
1x Cooler Master HAF 932
http://www.crazypc.com/products/haf-932-81226.html
- Supposedly one of the best if not the best air cooled case, and I am sick of mid tower cases so this would be a nice boon to go full tower.
1x Prolimatech Megahalems Lapped
http://www.crazypc.com/products/prolimatech-megahalem-508600.html
- Best air cooler (tied with TRUE?) either way its cheaper than the TRUE and I can get it lapped for $20 more. Pretty much the defacto best cooler.
4x120x38mm Fan Clips
http://www.crazypc.com/products/508601.html
- Need to attach those fans![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
2x Panaflo 86CFM fans...
http://www.crazypc.com/products/5787.html
- Going for a Push Pull Config and I don't need 70DB 250CFM fans because this has to be a realistic config that won't sound like a jet engine taking off in my office.... needs to be quiet, but there is some leeway here regarding sound levels...
1x 230MM Blue LED
http://cmstore.coolermaster-usa.com...d=178&osCsid=3da0cdadb41c02089a09c47d2a2483e6
(Going for red to blue for my HAF 932.... so I will need to switch out front fan)
10x 120mm blue LED Cooler Master Fans
http://www.crazypc.com/products/cooler-master-5834B.html
- 4 for side panel intake, 1 for bottom PSU area intake, 1 for front intake, 3 for top, and 1 extra...
1x Scythe Kama Bay
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185020
- Will put 1 of the Blue LED fans in here for additional intake...
1x 140mm Blue LED FAN
http://www.newegg.com/Product/Product.aspx?Item=N82E16835129248
To replace back fan (whcih is solid black)
Approx Cost
~$425 Shipped
Any Input?
1x 230MM Blue LED
1x Scythe Kama Bay
Approx Cost
~$425 Shipped
Any Input?
