Does this case exist? (smallish Mid tower fitting full ATX)
Zarathustra[H]
Extremely [H]
Essentially, I am looking for the best of both worlds.
Small, and sleek, but large enough to fit a full ATX board.
You know, a mid tower, that fits a full ATX motherboard, but ends right where the motherboard ends, without the front stack of drive bays. (instead a single small 2.5" mounting bracket could be on bottom of case) Doesn't need to be wide enough for a 5.25" bay (I don't use them anyway) so the tower could be just wide enough to fit a full-height PCIe card, and no wider.
Been searching various sites, by using filters, and sorting, but have yet to find any in which I can sort cases by size, dimensions or footprint, which makes this a rather tricky task.
Essentially what I am looking for is a case fitting a full ATX board that stops existing outside of these red dotted lines: (yes, I know the PSU will be problematic, but there are smaller form factors there (I have one) or some other clever mounting orientation could be figured out.
Has anyone ever seen anything like this?
Much appreciated!
Maybe try looking at desktop cases because hdd cages above mobo and rotated psu seem like only option here.
NZXT S340 ditches the ODD location so it's very short length wise... but it's still wide with the PSU having a traditional bottom mount. It is still a little smaller than some Micro-ATX towers(350D) though.
200mm x 445mm x 432mm
7.8 x 17.5 x 17
7.8 x 17.5 x 17
I would second this, it is a tiny bit taller than a 350D probably not as wide, and can still hold up to a 280mm AIO. Loving it cannot explain how good the wire management is in it for this size case. Even if you toss your stuff in you would have to try to make the front messy! Oh and... it's a 70 dollar case!
Nice. Thank you for that recommendation guys.
The NZXT S340 is now my top contender.
