Huh?Does thermal Grease cause cancer?
well...does it?
I wouldn t spread it on my offspring but its probably harmless as long as you don t ingest it.
Even if someone used a particular, easily commercially available thermal compound on a daily basis, there's no reason to believe that he'll get cancer from it. The ingredients of the various thermal compounds are relatively inert. Even if someone were smearing it on his hands on a daily basis (that would get expensive pretty quickly), no such cancerous growths would pop up.
Now, if I injected Arctic Silver or Arctic Ceramique into someone's veins, I have good reason to believe that they wouldn't live for very long. Or, if I forced someone to swallow the compound, while hitting them in the trachea, I suppose I could make them choke to death on it.
Keep in mind, that *anything* can be dangerous. After all, if I injected a rat with water, in the amount of 10,000 times the dose that a human being would take in a typical setting (8 ounces), I'm pretty sure that the rat would die after having 80,000 ounces of water injected into him.![]()
well...does it?
well...does it?
This thread has my vote for Most Awesomest Title Ever on [H].
-bZj
Thermal paste such as AS5 is 99% silver, which doesn't cause cancer, but who knows about the last 1%.
It doesnt cause cancer. It causes AIDS!![]()
Super AIDS?
as far as i know as5 is not 99% silver... on their website it says its contains 99.9% pure silver in other words the silver that is in it is 99.9% pure (not bonded with other elements). It also says Arctic Silver 5 contains over 88% thermally Conductive filler by weight. If the word filler is to include the silver then it is at most 88% silver (though not likely because it contains other solid materials) but if filler is meant to imply only the other contents then it is at most 12% silver. It would be my guess that the silver content is more around 20%
already tested AS5....its weird, u cant get it out of ur mouth
thats why i was asking, its been a few days and i'm not dead, and i haven't felt different
