Does the BadAxe2 OC well?
ymee
Im in the planning stages of setting up a new computer for myself. Been an AMD man for the last 6 years but the Intel Core Duo sure looks like a nice chip. So heres my question, after reading a bunch of reviews on the various platforms for CD it looks like the NVIDIA chipset based models are out as they are just plain unstable. In the Intel camp it looks like the BadAxe2 is a nice stable board. I am not planning on overclocking much, but if I did, does this board let you overclock? I am planning on getting the 6400 or the 6600, l like the extra onboard cache on the 6600 and I hear they overclock about as well as the 6400.
What do you guys think?
The Bad Axe 2 will overclock very well and is one of the most robust motherboard in the market. I'm ordering one myself :)
The only thing that this one can't do very well is reaching 450+ MHz FSB but if you get a 6600, it won't be a issue due to a higher multiplier so it's a perfect marriage ;)
dont think you would need a bx2 for a 6400-6600 oc, cost a bit much for my taste, but if you have the money then go for it
well someone smarter than me said follow the overclockers, so head down to the intel cpu section and you'll find the core2 oc database, it has details on who did an oc with what, i think you'll find something of ur liking :)
BX2 is perfect for o/c on a chip like the e6600 b/c of the higher multiplier. Plus, there are no strap switching issues like on most P965 boards. Reason the P965 is better for the lower multipliers is b/c it can reach the higher FSB.
You can get the BX2 for $200 or less anyway, I'm running one w/ an e6600. The 975x is a stable and mature platform.
Cool
I am now thinking of he BadAxe2 or the Asus P5W DH deluxe with the 6600 C2D processor.
For ram I am going with the g.skill http://www.newegg.com/product/product.asp?item=N82E16820231065
For video card the EVGA 8800GTS with 575Mhz core clock (instead of stock 500)
http://www.newegg.com/product/product.asp?item=N82E16814130080
Should I use the stock cooler that comes with the processor or go for this Zalman...kinda worried if it will fit or not.
http://www.newegg.com/Product/Product.asp?Item=N82E16835118112
mmm yes the cooler also got me pondering when i was looking for one for my p5b-e, in the end i just went for a cnps9500 because it is standing and blows the air out the case, not to mention works great
If you want a Zalman, why not look at the CNPS 9500/9700 coolers. The CNPS9500AT has the 4-pin PWM fan that is controlled by the motherboard. They both fit the BX2 also.
woohoo just got an email with my tracking number from newegg, looks like my new system should be delivered Friday. I ended up getting the following
CPU INTEL|C2D E6600 2.4G 775 4M R
MB ASUS P5W DH DELUXE/WIFI-AP GREEN
VGA EVGA 768-P2-N831-AR 8800GTX R
MOUSE LOGITECH|MX 518 USB RETAIL
CPU COOLER ZALMAN|9700 LED RTL
PSU OCZ|OCZ600GXSSLI 600W RT
MEM 1Gx2|G.SKILL F2-6400PHU2-2GBHZ
SNDCD CREATIVE|70SB073A00000 RT
I hope the Asus board has the latest BIOS so it boots the C2D proc. If you guys have any tips on building this system let me know. The one thing I am unsure of is if I have to load SATA drivers during the winXP install or not.
All the P5W bioses will boot C2D chips, so you should be fine there. I don't recommend the newest bios though (1901 or something like that). The 1707 seems to be fine though.
You only need the drivers if you run in RAID or AHCI mode.
This is what got me sold on the BaxAxe2.
http://www.legitreviews.com/article/395/4/
The QX6700 running at 3.667GHz. Original, I was thinking of getting the nVidia chipset, but seems like they will never get it fix anytime soon. So, I might just say good-bye to SLI and the 1333MHz FSB, and get the BadAxe2 or Gigabyte DQ6 Rev3.3(which has 1333MHz FSB).
Does anyone know any other motherboard that will allow the QX6700 to achieve this kind of speed or higher with active air cooling? Otherwise, my choice comes down to the two MB I mention above.
Thanks!
whats wrong with the latest BIOS?
For some people the bios install got corrupted, some overclockers wrote the bios was working on installation but after a reboot their settings were discombobulated. When they tried to go back to earlier bios they couldn't do it as easy as they used to be able to. Another Asus bios for another board got pulled off site because it crapped up peoples units so don't rush to install these updates. People talk about it in the P5WDH thread here (last 5 pages or so) :
http://xtremesystems.org/forums/forumdisplay.php?f=59
Also: You would be well advised to install your drivers from the Asus site. The Asus driver CD's have been notoriously problematic. I couldn't even get mine to make SATA drivers that install at the F6 stage. I had to make them from Intel site before hand. The Marvel Driver on disk wasn't a problem for me though (thats for the network so you can get online as you probably know). The Asus utilties can be buggy too. The AI Booster and Probe can say your cpu or board is at 250c when its at hardly even warm. Between the new C2D and Vista there is a lot of wierdness going on and support staffs are spread thin. However the bios your mobo comes with should be ok. 1701 is what I am on (my board came with 1201 last September and I was spared the no C2D boot issue) and that fixed the SLI boards that weren't booting in Vista. Most of the obviously wierd stuff has been fixed so don't mess with that new Bios yet. I was updating from the windows utility and it was quite easy and effective but I have doubts about it at the mo.
