dioxholster
- Aug 11, 2010
for instance months ago i replaced my video card but havent reinstalled windows. And i thought that was okay because all works fine. But in forums i read that its optimal to just reinstall.
The only time you should reinstall is if you replace the motherboard. Even then, if you run sysprep /generalize /shutdown, then replace the motherboard, then start it up, it's like you're reinstalling all drivers anyways. If you do that, you don't have to reinstall.
Otherwise, all hardware can be replaced without reinstalling. A best practice is to go into the device manager and remove the device, as well as any related software in add remove programs. Then shut down, add the new hardware, and start it up.
From what I've seen of it while using it, yes. /generalize will strip out all hardware specific installations and security id's from the OS. It also resets activation. So if you use it on a retail install you'll have to input your key again. /oobe just takes you back to the screen where you do all of the initial setup stuff.Does sysprep still work that way with Win 7? I thought I looked into it a while back and it was totally changed.
It's interesting to see this topic in here today.
Just yesterday I replaced my motherboard (ECS a790gxm-ad3) that was giving me issues with an Asus M4A87TD/USB3 and everything worked right away. Windows 7 detected some changes after I booted up, reinstalled some drivers and upon the next reboot it was working perfectly fine as if nothing had changed.
I believe the fact the chipsets are similar have helped me though. Other than a few hardware functionalities, the same driver packages are used.
Nah, that's a minor upgrade. Reinstalling the entire OS is recommended when you swap out the entire motherboard itself - all the other components won't really cause much issues, even a CPU upgrade more than likely isn't anything at all.
But a new mobo typically is so different that a clean install is - again - the recommended course of action.
Just bumping a video card means new video drivers most likely and not much else going on.
