Alright, My cores orignial speed was 250mhz. I've over clocked that up to 274.50 mhz. The memory on it was runing at about 200mhz. I clocked that up to 220mhz. Than i saved the setings and restarted. Now the program that i am useing is called Radclocker. It shows my setings as i set them. But does this really work? I can't really tell much of a difference in gaming. I relize this is a small overclock but, still. Is there another way i can see if this really did change my settings?
The card is a Radeon 9550 if that helps any.
