Does Internal Target Failure has to be Hardware drive defect?
Happy Hopping
I went to Wiki, essentially "Internal Target Failure" is hardware error. Could it be something else?
I got this Pioneer BDR-203 that is just 1 yr. old. It's made in Japan. And I burn on an average 1 DVD+DL per day in the past year. I burned only 2 dozen Blu Ray in the past 1 yr.
So there is no excessive use at all. But today, w/ Nero 9, I got the aboe error.
But when I use another software to burn 2 more DVD, 1 x DVD+R, 1 x DVD+DL, there is no error.
So either it's a bad disk, or it's an intermittent failure on the drive. But the disk that I use is Grade A, made in Singapore Verbatim DL. It has never failure before. What's the verdict?
You get an error with with Nero but not with another burning program?
I would consider that a program error rather than a hardware error.
IDK if burning a disk a day is considered heavy usage but I burn much less than that.
