- Oct 29, 2000
Anyone have any experience with this?
Appreciate any input
DP 2.0? Only Intel Arc cards have that and suffice to say it's useless on those cards..only the 7900XTX may derive some tangential value from it.4xxx is still DP 1.4 and the 4090 is arguably the only card that could have actually used that bandwidth. You need a USB switch and DP switch , yes one more button to push but quality ones should not run more than $25 each, what I use now.Hmm.
Might be moot. I can't find any KVM switches that are DP2.0 or higher. They are all 1.2 or 1.4.
That is a shame.
