I have an FT02 as well.
Vertical mount cases like the FT02/Raven cases are better in terms of gravitational strain (in a normal tower case with horizontal mounting of add on cards, the PCI-E slot is going to take lots of the strain of the card's weight, especially if you happen to put the case down hard, or if there is heavy vibrations/impacts nearby), but it doesn't do anything for external wires twisting cards that they're attached to. In fact, with the FT02, wires have to be bent quite abruptly so you can put the grill lid/cover on, so that can actually cause more strain and twist the card even more.
So a vertical mount tower, or desktop/HTPC case can only help with cards sagging under their own weight.
