I breifly ran twin 74GB Raptors in a DangerDen AquaDrive cooler and was hard pressed to see much point.theseeker said:I was looking for people with first hand experience.
sprocket said:Fooling around with a laser thermometer and a running harddrive showed me that the main heatsources on a HDD were the area around the drive motor and the PCB...NOT the sides of the drive as commonly held. Although it would be simple for the manufacturer to incorporate waterchannels into the casting of the drive body, I have yet to see an aftermarket cooler that properly addresses these areas so IMO adding drives to a waterloop is not terribly beneficial.
I sure hope you're not referring to this AC cooler...Top Nurse said:Absolutely correct so it was unlikely you would see any difference with the DD cooler you were using. That is why the AC, Koolance, and others work so well. It gets rid of the PCB and spindle heat and also quietens them down as well.![]()
{NcsO}ReichstaG said:Some guy posted a picture of his AquaComputer block for his HD.
But seriously, what's the point of watercooling a HD? I don't think lowering the temps on it with water rather than a simple, slow 120mm fan will increase the HD's life that much more...
The HD is bound to fail (i think) as a result of other reasons first, before it fails because it consistantly ran 31C with a fan as opposed to 25C (just an example) with WCing...
EDIT: here is the thread:
http://hardforum.com/showthread.php?t=1041226
Thats pretty stupid for things in your case that need cool air on them like mosfets and the like.Volkum said:Wouldn't the point be to eliminate fans though? Personally, I'd love to get a water setup and eliminate EVERY fan except those on the rad.
It's a great idea, but unfortunately I think you'd be better served by placing a 99.9% silent 120mm fan blowing slowly on the HDDs. IMHO in order to properly cool a hard drive you would need to slather those things in some sort of TIM to properly interface with the block....I don't think anybody really wants to do that.Volkum said:Wouldn't the point be to eliminate fans though? Personally, I'd love to get a water setup and eliminate EVERY fan except those on the rad.
CrimandEvil said:Thats pretty stupid for things in your case that need cool air on them like mosfets and the like.
sprocket said:I sure hope you're not referring to this AC cooler...
I fail to see how that could achieve much of anything.
And the Koolance coolers keep your drives at what temp?Top Nurse said:That is the reason I don't use those coolers because you need one of these thermal pads for it to work well. I prefer the Koolance HD coolers because you don't need the extra expense of a thermal pad.
