Eastcoasthandle
- Jan 27, 2006
This is a food for thought thread:
Can 1 pint of water circulating in your loop (usually found in some T loops) help increase temps no matter how well you rad cools it?
VS
Can 5 gallons of water circulating in your loop help decrease temps no matter how well you rad cools it?
For the sake of information lets assume this is a hot summer day, it's 90F outside and in your computer room ambient temps are 30C. For most that 5C-7C higher then normal when window fans, A/C is used.
The point I am trying to get to here is:
Can having more water make it harder for it to get hotter quicker when other factors affect it's temps then just the CPU/GPU/Chipset?
For example:
Water that's consistently in a loop going from pump>rad>CPU>GPU>back through the loop again.
vs
Water that exist the loop into a larger pool of cool, un-circulated water to be used. I'm not talking about 3 liters, more like 2 gallons. From pump >rad>CPU>GPU> dumped in 2 gallons of unused water.
What are your thoughts on this?
VS
For example:
vs
