TwistedMetalGear
- Jun 19, 2005
I have a Sandisk SSD just under 3 years old. Recently it has started to fail the S.M.A.R.T. test during POST so I had do disable the test in BIOS. The drive boots fine most of the time, but other times it will fail to read files during boot and Windows won't load.
Is this something that a reformat can fix or does a failed S.M.A.R.T. test always indicate a failing drive? In other words, should I even bother wasting time debugging this, or should I go straight for a replacement since I am still under warranty?
I appreciate the input. Thanks!
