Does a case like this exist?
TeeJayHoward
Limpness Supreme
Like the title says. I could have sworn I saw a mini-ITX case like this a couple years back, but I can't recall where.
If it doesn't exist, how expensive would it be to make something like this at home?
The closest thing i have seen is the lian li pcq08
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112265
All three of those have the power supply mounted above the motherboard. The one I'm thinking of didn't.
Also, holy cow those things are huge. 14"x9"x11"? The one I sketched up was something like 8"x8"x11".
Best bet would probablybe to just make a case like that on your own. Wouldnt take that much, some aluminum posts and sheets and a hacksaw and you have a frame. Then take apart a cheap case for the bays and mounts you need.
I went with the lian li pcq08. I was able to stuff a micro atx mobo, 8 hds and one ssd. Its not tight but its still has good air flow.
