- Aug 25, 2010
Do you prefer a lighter mouse or a heavier mouse?
I feel a heavier mouse is more stable, easier to make fine movement adjustments, and easier to track enemies with.Less weight is objectively superior for competitive gaming.
Newton's second law.
I had a G502 (wired) for a couple years and then a Superlight for couple years. The Superlight took some time to adjust to and I felt it was almost too light.
Then again, in a world where nearly everyone prefers and favors low mouse sensitivity, I play with high sensitivity.
I had one like that. I installed all the weights it came with. Fully weight loaded mouse still doesn't weigh much. Not like I couldn't chuck it across the room with a flick of my wrist. The weights add grams, not kgs. It's about feel, not performance.Anyone remember Logitech including a little tin full of weights you could add to your G5 / G500 mouse? I I quite prefer a bit of heft to my computer mouse .. I really do not want or understand why anyone would want they super light mice that are selling now.
Optimus has many great videos, but there is one more important thing to be added – the mouse feet. Unlike plastic feet, metal feet have much less resistance and glide more easily, which makes even heavier mice move easily.
My current Bloody Naraka moves very lightly, and the mouse is heavy.
On the contrary, I find that a lot of my gaming and other use benefits from a mouse that has lots of additional functionality. I used to like the "MMO" style mice when they were popular years ago, but always thought the button grid could be improved or other features could be added depending on design. I currently use and favor a Swiftpoint Z2 ( https://www.swiftpoint.com/products/gaming-mice-swiftpoint-z2 ) .
I'm not sure which mice you used in the past and everyone's hand size and comfort is different, the Z2 finger buttons are relatively unique and well placed in my experience. When you describe the difficulty with bending your thumb back for MMO mice, I can remember similar annoyances with many grid-ish layouts, but one of my biggest gripes was the lack of a "blank" space for your thumb without disabling a button. You'd need to be able to grip the mouse to lift and move it, and doing so without entering a command on the macropad could be an issue unless I picked to disable one of the middle buttons entirely. Thankfully, some later iterations of MMO mice got around this issue , but the Z2 has an even better layout than a thumb grid/hex, in my experience.While that's an intriguing concept: as someone who tried using an MMO mouse in the past, I fear that even if it had one additional feature (button position reversibility for left handed use) the finger buttons set back behind the scroll wheel would have the same problem that crippled the MMO mouse for me. Repeatedly bending my thumb back enough to reach the back half of the thumb pad rapidly became painful (I mostly ended up using just the front 3 buttons, with the next for very occasional clicks); having to curl my fingers back almost into a fist the way their demo video shows looks almost as uncomfortable.
