fightingfi
- Oct 9, 2008
Do they make a case fan that has extra holes in it so you could add a larger fan to the case for example taking a 140 mm case fan but make it with extra holes to fit into a 120 mm area or vice versa, that way you could add a larger fan to your smaller AIO and mount it on the back or top of your pc case?
