do they make wireless dial up routers?
slightlyhuman
noob here, i have wireless broadband.
my gf lives in the country and can only get dial up. they just bought my laptop but i was wondering if they have wireless dial up routers, etc.
any help would be great
thx
Wireless dial-up, like going from a wireless connection on a computer, to a wireless access point, then to a dial-up router? If so, I do not know of any combo products offering wireless and dial-up... you could buy them separately.
well, on my wireless network, my coax cable goes to the cable modem, then a cat5 going to a wireless router. i didnt know if they made something similar to that so she could surf the web wirelessly even though its dial up.
oh well=/
You'd need a dial up router with a wireless access point connected to that using cat5.
I saw a couple of them for about $65 on the internet. Nobody really makes them anymore, but you can still find them.
My D-Link router has a modem and printer port on it. You connect a modem with the modem's serial cable and it will use it to connect via dial-up. If you had a router like this, then you could put on a wireless access point on it via a ethernet cable.
