If your southbridge needs a waterblock, something isn't right. A decent passive heatsink should be fine.
when you amp up the MCH voltage the southbridge can get quite hot.
In my experience, most southbridges DON'T have any holes around them. What little cooling they have is usually just held in place with thermal adhesives.well, NB and SB chipset mounting styles are usually pretty much the same. The design of modern SB and NB mounting is just two holes, all you have to do to make sure the cooler fits is make sure the two holes are the a distance apart that is acceptable for the south bridge.
Im sorry, i dont know the dimensions of the XBX and XBX2 mobos, but im sure if you look around you can find a cooler that fits. take the measurements. and just check swiftech.com, dangerden.com, etc etc. Im sure you'll find something that fits.
one thing that would be nice to know, do the fans function under oil? can you use them to correct oil-flow (as in air flow w/ the oil)![]()
tell that to 680i
28 PCI-e lanes, controll over 6 Sata slots, and everything else, generates a fair chunk of heat.
anywho, to the OP, this might be something to look into. shoot em an e-mail tho.
As such, no- I don't know of any southbridge water blocks. There just wouldn't be any way to mount them.
I'm going with Aquacomputer for my northbridge cooler, and if it's as you say you can just mount a northbridge block onto the southbridge then I may just buy two of them.
