Put together my sig finally and unfortunately there's a slight problem. The 8800gtx doesn't sit all the way in the pci-e card because of a motherboard fan on the MCP chip. I powered up anyway thinking I had sufficient contact on the pins. Well, everything seemed to spin up fine, but I had a blank screen staring back at me. I have speakers hooked up to the motherboard and I heard no beeps.
So I'm wondering...I think it's the vid card, but if the ram is my problem, would I hear any beeps? If there is no video signal, would I hear any beeps? I heard no beeps, which leads me to believe that everything is fine (or will be once I figure out the video card). However, I don't know if newer systems even issue beeps upon problems. There was no "beep code" with my XFX motherboard manual, so maybe there are no audible codes?
