Do mobos come with screws?
So I have all my parts and I'm like a kid in the candy store starting to put my new PC together. Everything is brand new except I'm reusing my old case. I'm about to put the mobo in the case and I have no screws. I sold my old mobo months ago and I've build a PC 4 years ago so I don't remember what came with the screws. Probably the case. I have some spare ones, but they're not here. Gotta drive half an hour to get them. I guess when I pay $180 for a mobo, Abit IP35PRO, I expect a couple screws to mount it. Do screws only come with cases?
Sorry, your SOL.
The screws that mount most HD's/case side panels are compatible with MOST mobo standoffs. Mount if with one for now, and get the rest in later ;).
screws come with the case.
the good news is that with the onboard power & reset buttons who needs a case? :p
I'm thinking of just laying the pc on the side for tonight.
I wouldn't really recommend that because a powered motherboard slipping off the standoffs because of some accident isn't a good way to treat a $180 board.
jfc - order online and pay a fortune for a 4 cent scerw. Hmmm well with a 1/2 hour drive to town and $3.00 gas, lol, might be cheaper to order over the net.
They are #6-32 1/4 inch (maybe 3/8, you can tell when you get to the store and have one in your hand) long pan head (or hex head or phillips or straight slot) screws. any decent hardware store will have them. Take a standoff along just to be sure and test fit a screw. Same size is used to secure the card brackets to the case for plug in cards and to screw down hard drives. Floppy and CD drives use a smaller finer thread screw that I dont know what the size/thread is offhand.
Be different, get some hex head black cap scews if you happen to go to a really good hardware store. Sexy ;)
