Do I need to reinstall windows for same exact mobo replacement?
lend82
Hi=]
I had a DFI Lanparty UT NF4 Ultra-D motherboard that was destroyed recently, and was hoping on getting the exact same motherboard. I hope that doing so, I will be able to log straight back into windows, avoiding losing everything by reinstalling windows--if I bought a different motherboard.
My question is, is what I want to do even possible? I mean, most importantly, is it SAFE to use the same exact make and model motherboard, to log right into windows and start where I left off? Or do I really have to reinstall windows just to be safe?
All my hardware will be the same minus my x-fi, which was also destroyed with the motherboard. As far as not having the x-fi installed, I think that wouldn't be a problem: from experience, I will just have to uninstall the drivers so windows won't keep trying to recognize the card.
Anyways, thank you for your help, have a nice day!=]
*edit* I'm thinking of getting an sli motherboard instead of my original motherboard btw, because prices of decent video cards are constantly falling, which may make it easier for me to have good video performance via sli, while spending a minimum amount of money. Feel free to tell me if I should go this route instead=]
O yea, I WILL be overclocking, so I'm not sure if I should go with the sli board, or the Ultra-d board, which is a well-known overclocker(I personally oc'd my opteron 800 mhz stable on the Ultra-d)=]
It all varies on the individual case really. If it's precisely the same unit: same revision, same components, you'll probably be ok. But even then I never do it. I've just had boards do strange stuff in the past even if they were the same model yet be a different revision and have slight differences in the way the hardware interfaces with the driver. Backups and automated install disks are your friend, as well as norton ghost.
Hi=]
I just ordered a new mobo, the exact one I had before. I will be sure to let you know if it works without any problems.
Thanks for the responses guys, you've been a great help!=]
I decided to buy the sli motherboard, since I wanna futureproof myself in a cheap way via sli, for upcoming games like ET:QW and ut2k7. Hopefully I'm doing the right thing.
Have a nice day guys, I appreciate the help. Later!=]
I'm not convinced you necessarily have to - I guess it depends on the boards. I went from a 680i board to a P965 board and did not have to reinstall windows. 0 problems here.
you should not have to reinstall windows, but you will want to uninstall all drivers associated with the original motherboard before removing it, and then of course install the latest drivers for the board you want to install after the hardware swap
if you want to be sure, go to the device manager and right click on everything under "IDE ATA/ATAPI controllers" and choose uninstall, this will almost guarantee you not having to reinstall windows, even if you move between very different boards, as long as you dont change much else in the system, windows wont care
Exact same board you should have no problems. The chipsets are usually what cause the reinstall of Windows. If you're running the same chipset, and the onboard sound is a little different, it will just prompt you for drivers.
Exact same board = no problems, provided your BIOS is up to date. Just make sure that you have the cards plugged into the same slots, and that you have the BIOS configured the exact same way.
Different board, same chipset = usually no problems. Some drivers for the addons (built in sound chip, firewire, RAID, etc) might be different from one brand to another, but for the most part, this is easily fixed. I've done many replacements of boards that used the nForce3 250 chipset, with relatively newer Gigabyte GA-8KNS Pro boards, no real problems other than having to install new ethernet and sound drivers.
Different chipset = usually has problems. Sometimes, you'll get lucky, and Windows will load up some generic drivers and you'll be able to install the new drivers, but I generally don't like having all of that clutter.
In general, going from a less advanced to a more advanced chipset has a greater chance of success, but if you get too far ahead, you may find that you'll have to at least do a repair installation, which is more often than not. My success rates of upgrading older AMD 761-based motherboards to nForce2-based motherboards were much better than, say, downgrading systems that had nForce2-based motherboards, to the older VIA chipset ones.
Different CPU sockets = I usually just reformat.
Thanks for the responses guys!
My new motherboard should be coming today(soon actually). It is slightly different than my destroyed motherboard, as it's a sli version. This new motherboard is the DFI LANPARTY UT nF4 SLI-D, and my previous, destroyed motherboard is a DFI LANPARTY UT nF4 Ultra-D(the former is a sli mobo, the latter is not). I think they have the same chipset(nf4), same intergrated sound solution, etc. But as someone mentioned above, my previous motherboard was unexpectedly destroyed, and I have no way of uninstalling the drivers for that mobo.
I'm hoping that WITH the old drivers installed, I can use this new sli motherboard and install the right drivers, if needed. As some of you have said, this seems to be possible. SO, I will just have to install the new drivers when windows recognizes the new motherboard, right? And, will I be able to uninstall the old drivers and stuff via windows add/remove programs?
If my new motherboard comes before one of you post, I will just go ahead and reinstall windows--too anxious to wait for computing!
Thanks for all your help guys, have a great day!=]
Those two boards have the same driver package IIRC. If you plug your HDD's in the same spots they used to be in, you might not even miss a beat.
Thank you for your help!
I figured they might have the same driver package. I don't think I remember which sata port I used for my harddrive on my previous install.
Grr I was just looking at UPS down the block across the street. When are they coming to me!! I'm getting all paranoid and stuff. Anyways, I hope no other components were destroyed other than my x-fi and mobo=]
Thanks for the help guys, have a great day!=]
I wouldn't anticipate you having any problems... at all. The loss of the sound card won't make any difference.
I would at least try and update your BIOS to the same version you were running before to keep things similar.
The Ultra-D and SLI-D are the same board. The only difference is the SLI-D nvidia chipset has SLI support, but it's a well known mod to upgrade the Ultra-D to SLI support using a pencil to connect a couple dots on the chipset. So for all intents and purposes, they are the exact same board.
(by the way I have one and have read extensively about it)
I just installed my second DS3 in this computer with no need to reformat. The only problem I had was with my network and that was just because Zone Alarm is pretty anal about it. :)
In my experience even when they board is the same kind, windows notices and asks for reactivation because of major hardware change. Never had to reinstall though.
Different motherboard means the the NIC will have a different MAC address, so I'm not surprised Zone Alarm got a bit mad about that :p
Thanks for your help guys!=]
I got my motherboard and tried to zoom straight into windows. It worked the first time I logged in, but when I rebooted, I couldn't get back in. So I reinstalled windows=] I'm currently on my computer trying to get my cpu speeds again with this opteron etc, haha:p
Have a great day guys, later!
If there are so many problems even with the SAME motherboard, how are administrators able to get away with installing the same exact ghost image on many identical hardware systems?
Did you figure out why it did that or did you just reinstall anyway? Repair or full reinstall?
Good point=]
Nah I didn't figure out why. I was too weary of doing any further damage to my beloved hardware that I went ahead and did a format=D Good news though: I overclocked 700 mhz on the first try without one single problem. BF2 and Quake 4 stable. This was using the same oc'n settings I used with the Ultra-D motherboard. So I'm pretty happy, hehe=]
