- Aug 25, 2010
I have my Vcore set manually at a static 1.190 volts in the BIOS even though the BIOS states the stock Vcore is 1.305 volts. During Prime95, the Vcore drops to 1.116 volts and I get no BSOD or anything. My 3930K turbos to 3.8 GHz across all cores during load.
I just got my RMA'd cooler replacement (H100) and my idle temps are 18-24 C, BIOS CPU temp is 28 C, and my temp during IntelBurnTest is maxes out at around 44 C.
I played a 24 minute round of Battlefield 3 multiplayer and the max temps ranged between 35-38 C. During Battlefield 3, the Vcore was around 1.124 volts.
Basically, isn't my 3930K taking a lot less Vcore for the speeds it is running at (3.8 GHz with 1.116 volts in Prime95)? I guess I have the temps to back it up too.
