Displayport MST hub $90 @ egg.
/dev/null
Link
This is $159 at amazon.
Also: To save some reading @ EGG, this is how many monitors @60 hz you can run off one displayport connector:
Radeon 5xxx
1366x768: 5
1600x900: 3
1920x1080: 2
2560x1440: 1
Radeon 6xxx/7xxx
1366x768: 6
1600x900: 6
1920x1080: 4
2560x1440: 2
Does this allow for extending the desktop or will it just mirror the desktop onto additional monitors?
the MST is suppose to be the daisy chain hub for allowing multiple monitors (extended) off one display port
This++
This lets you use 3 displayport monitors off of one displayport.
Also: If you use a mix of DVI + Displayport & see tearing in Eyefinity, All monitors running off one MST is supposed to fix this as well.
