Flogger23m
- Jun 19, 2009
Hello,
I have been having the following issue for a while. I will describe it below:
1) I upgraded to a EVGA GTX 560ti 2GB (From 260 216 Superclocked). When I turn off the PSU or unplug it, then power the PSU on/plug it in and press the power button my PC boots fine every time. I can play games such as BF3 and ArmA 2 for hours with no issues.
2) However, a normal shutdown from Windows and then turning the PC on without turning off the PSU/unplugging first causes an issue. The POST beep is delayed, however it eventually does POST. However, there is no video displayed. The video card's fan is still spinning. I can hear the HDD accessing, loading into Windows most likely.
3) I ordered a replacement from EVGA. The 3rd card worked flawlessly in terms of powering on for about a week. Today the issue described above occurred again. I tested it a few times, and the issue persists.
4) I doubt the video cards are the issue at this point, so I bought a new Antec Earthwatts 650 PSU (check newegg for specs). This did not fix my issue. It was as if my old Earthwatts 500 was in my PC. I doubt both PSUs have the same issue.
5) Put my video card into an entirely different PC, also with an Antec Earthwatts 500 (3 years old). It powered on fine 3 times, and BF3 worked fine. I doubt my video card is the issue.
I think it is safe to assume that the PSU(s) and video card are fine. This leaves me to believe my motherboard is the issue. How can I determine/test the motherboard? I have the latest BIOS for it (1402) and it has been working fine until I received my first GTX 560ti.
What other things might be causing the issue?
I am guessing it might be an issue with the motherboard, though it worked fine with the GTX 260 Superclocked core 216. If it is a PCIe-related issue on the motherboard, would clearing the BIOS and reinstalling the latest bios version resolve the issue? I should also mention that there is no apparent physical damage or obstruction on the PCIe slot itself. I will also note that the original BIOS versions for my motherboard will not support my CPU (AMD 965), and I have no CPU that will work on the original BIOS version. If I were to revert to the original BIOS with the AMD 965, will I be unable to get into the BIOS/ASUS EZ Flash to update them?
Edit: After putting the video card back into my PC, I put the entire PC onto a different surge protector and outlet. It worked fine for two normal starts/shutdowns, however on the 3rd attempt the same issue occurred. So I doubt my outlet or surge protector is causing an issue either.
System specs:
ASUS M3N78 Pro Motherboard
Corsair XMS2 - 4x DIMMs, 8GB total
AMD 965
WD FALS HDD
Samsung 223F DVD/CD Drive
2x case fans
1x PCI Card
Viewsonic 19"
Win 7 Pro 64bit
System #2 that I tried my 560ti in:
ASUS M4A88 T-M
AMD 1090T
2x SATA HDDs
Win 7 Pro 64bit
4x DIMM DDR 3, 8GB total
2x case fans
1x DVD/CD drive
Samsung 24"
System specs:
AMD 965
WD FALS HDD
2x case fans
1x PCI Card
Viewsonic 19"
Win 7 Pro 64bit
ASUS M4A88 T-M
AMD 1090T
2x SATA HDDs
Win 7 Pro 64bit
2x case fans
1x DVD/CD drive
Samsung 24"
