Display is not coming
mwvirk
My computer shutdown automatically.
Later I tried to switch on the machine again but it (CPU) gave 1 long beep and then 3 beeps.
On monitor, it shows that it's trying to find signals (showing HDMI - Digital - Analog) and then monitor goes to standby.
Open the case and found that display card's (8800GT) is stopped and its not working at all.
Remove card and clean it. Still fan was not moving. Clean fan properly and used WD40 and fan started working now.
Placed card back and cabled. But still machine is coming up but there is no display. CPU is still giving 1 long beep & 3 beeps and monitor still showing HDMI - Digital - Analog.
I wonder if GPU is dead!!! But how come fan is working. Do i need to buy new GPU now. Pls help.
Without knowing the complete specifications of your system as well as all of the steps you've taken to diagnose (and narrow down) your problem, I'm going to have to take your word that the video card may have gone bad.
Is it under warranty? Are you able to afford a new video card now? Do you have another video card you could use to confirm the problem?
spec is like this:
cpu: c2q 6600
gpu: 8800gt :(
mobo: asus p5q
audio: using creative audiog 2 for 7.1
4gb ram
320gb c:
2tb d:
lg dvdrw
it's not under warranty as it ran fine for 3 years. i wonder why mobo didn't give any warning. like whenever gpu was getting over heated, mobo used to give beep. and if it shutdown when gpu is dead then it should shutdown when gpu was getting over heatup.
i am not in position to buy any expensive card now. could u please suggest what DX11 card can be fit on my mobo now.
thanks.
ok. i got response from most of forums that it could be GPU.
well, I am going to confirm this by installing some other card on my machine and try my card on some other machine.
now, if it is really GPU then i need to buy a new display card. Please help me find good DX11 card based on my mobo / sys config.
please help me and let me have list of few DX11 card with rating.
(ASKING LIST OF FEW DX11 - SO I CAN CHECK MY BADGET)
Well if it's the 8800GT, then yeah, definitely likely it's dead: I got a small stack of dead 8800GT cards next to me right now.
Well we need the following info:
1) What PSU do you have?
2) What's the max resolution of your monitor?
3) What's your max budget for a new GPU?
4) Are you using Adobe creative suite software?
5) Can you overclock that Q6600?
Motherboards check cpu temp and can shutdown if you have it set in the bios to do that.
Typically motherboards do not check gpu temp at all. I don't know of any boards that will beep, shutdown, or do anything resembling a warning if your gpu has a problem.
