natermeister
- Dec 26, 2005
I just picked up a second Samsung 204B from the FS/FT forum here. It's a great monitor, the problem is that the new one is definitely better than my old one.
The color on my new one seems to be, at least to my eyes, more accurate than my older monitor. I tried using the OSD and supplied software to match them up, to no avail. I don't know much about this subject, so I was pretty much guessing. I did make some progress, but not much. The new monitor seems to be slightly colder than the old one. The biggest difference is the color white. It looks like an off-white on my older panel, much like you'd expect to see a white wall look like in a smoker's house.
I've been thinking about getting Display Mate for it because after several hours of use I begin to develop a headache. If there are any tips or advice you could give me, I'd definitely appreciate it.
Thanks,
-Nate
Thanks,
-Nate
