Hey guys,
I need some help with a new problem that's cropped up on my computer on Thursday. First here is my build, put together in March 2006:
Everything is at factory speeds / voltages etc.
The problem:
What happens is that about 30 seconds into any GPU accelerated game, I get video artifacting and then the system hangs. On resetting, I'll get to the windows loading screen (with the blue progress bar) but then the display will show artifacts, hang and then my monitor will stop receiving signal from the GPU. If I shut off the box for a while; it will manage to get to the desktop and be fine until I try to game or run a 3D-accelerated program. This is 100% reproducible. Everything else has been fine so far.
I should mention that my system has never had a 100% boot up success rate; it will occasionally get stuck on the windows loading screen right before the login screen; and it will stay at that loading screen for varying amounts of time as well. Not sure if that means anything but there you are.
Diagnostic Testing:
My question:
How confident can I say that the problem is the video card? I don't have a multimeter to do power supply testing (I know..not [H]ard) and honestly, not sure I've got enough electronics experience to go down that route; and this is my only desktop so I can't do a parts swap.
Anyways thanks a lot in advance!
- Windows Home XP SP3
- Antec TRUEPOWERII TPII-550 550W ATX12V Power Supply - Retail
- Athlon 64 X2 3800+ Manchester 2.0GHz Socket 939 Dual-Core
- EVGA 133-K8-NF41 939 NVIDIA nForce4 SLI ATX AMD Motherboard
- G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
- EVGA 256-P2-N519-AX GeForce 7800GT 256MB 256-bit GDDR3 PCI Express x16 SLI Supported
- Seagate Barracuda 7200.9 ST3160812AS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
- ASUS 16X DVD±R DVD Burner W/ 5X DVD-RAM Write Black E-IDE/ATAPI Model
The problem:
Diagnostic Testing:
FurMark: Causes the artifacting after about 30s, GPU temp at that point is about 60C and then the system crashes.
Memtest86+: 5 passes without errors. I'm using v1.70.
Prime95: I've run for an hour; one core will get as high as 51C according to SpeedFan but only stays that high very briefly. The rest of the time T=48-49C. The other core stays at 46C. My GPU is a steady 46C too. Odd though, Speedfan rates the ambient temperature as 0C. Prime95 has gone through 1024K, 896K, 796K and partway through 640K without problem.
My question:
