Disabling TCQ on Nforce4
bokchoy
Asus A8N-E
WD Raptor 74GB
I'm trying to disable TCQ on my WD Raptor 74GB, but I did not install the Nforce4 IDE drivers because of some reports of weirdness (and also similar bad experiences with my Nforce2 setup) - therefore I'm just using the Windows drivers. The rest of the Nforce drivers I have installed (latest ver from the nvidia website)
I searched everywhere in device manager to disable it but there isn't even a SATA controller listing (and there's nothing listed under the Raptor). Everything works fine..but I read some reports that TCQ will hinder performance in single user setups like mine.
Should I install the nvidia IDE drivers?
Ok, thats why I was asking. I know the 10k drives dont support NCQ. Just trying to figure out what the TCQ meant.
W4ngsta said:
i think you have the asus A8N4-E or A8N4-E Deluxe, not a8n. the a8n is the nforce3 version.
A8N-E is the NF4 Ultra Asus board ;). The K8N4 is the s754 Asus board...maybe that's what you're thinking of?
I got my answer elsewhere, TCQ is not supported in the MS IDE drivers so I'll leave it as is.
Thanks :D
