Disable Primary IDE?
The Saint
Hi all...
since I'm using 2 SATA HDD and one DVD-RW PATA, I was wondering if disabling the Primary IDE Channels would make things faster and if it would be wise to do or not..
Thanks
Emanuele
I don't think it would make things any faster. You might save yourself a half second on bootup.
As for whether it is "wise" or not...it's probably more dependent on your situation ;), but I don't see why it would hurt to have it on. I didn't disable mine and I only use 1 IDE channel also. I figure it's nice to not have to enable it again in bios if I plug something in to test.
