Dire HELP Needed!!
Boxerz
my sister's computer was full of spyware and crap that you could not do anything when windows started up so she asked me to reformat her comp. she saved all her dental school files onto an external hard drive. well in the reformatting process, there was 2 hard drives that showed up and i believe i deleted her files on the external hard drive. i deleted the partition and when it was asking me to reformat the drive, i realized and did not reformat. now that the computer is fixed, my sister needs these files badly because it is all of her work for the top dental school. when i turn on the computer and look for the storage drive, it acts as if it doesn't even exist. windows detects a USB mass storage device but i can't do anything to it. i'm assuming the files and the program itself was deleted on the hard drive. she claims there was no CD that came with it to install it.
i've heard of forensic computer scientists being able to recover deleted files, and i am nothing close to it.. my sister is in tears and this is really important to her, any suggestions plz?
it's a Western Digital Hard Drive,
windows xp pro service pack 2
i tested the HD on 2 comps and same results
SpinRite is your best friend right now.
It works, assuming you didn't write any data to that drive after formatting it....
And in the future, always disconnect any hd's your not wanting to format when installing an OS..
Good luck, hope it works out for you..
You need to recover the partition.
Here is what I have used in the past: http://www.partition-recovery.com/
They have a demo, download it and see if it sees it to begin with. Then buy it and recover it.
What ever you do, do not do any writing to that drive. The partition is still there and the files are still there, you just need to recover them.
True advise above; you don't need forensics, just a program to rebuild the file table. When you delete files, the files aren't physically deleted; the file names in the file table are usually changed, sometimes be replacing some characters by an *, or some other method. I have recovered deleted files before from a hard drive, so it can be done. You may have to do some re-naming after the sofware recovers the files.
I think the link Met-Al provided would probably be a better choice in this case....and thanks for the linkage, never heard of that app before, good stuff.
thank you everyone especially Met-Al, you are a life saver for my sister. over 2 years of work was in that hard drive. i paid $40 and it worked like a charm
thanks,
-alex
thanks,
-alex
You are welcome and it is always good to hear a happy ending around here.
