marcusj3000
- Apr 9, 2005
you forgot that to play such disc's you would require
1) suitable optical drive
2) suitable display card
both of which can/do come with software and drivers
so why did MS have to bundle the DRM for BR/HDDVD into the OS?
They had to bundle the ability ti play all forms of protected content. Man... you still ain't got it that you are a minority, no matter how much you want the check box to uninstall DRM you won't get it. Most of MS software is made for OEM's that sell pebuilt computers. Most consumers buy prebuilt systems from OEM's and they don't want the headache of if they can play protected content are not so it's added to everybox of OS software sold whether it be retail or oem. You live in the DRM age and will never get the choice to uninstall it or not. The oly choice you will get is if you can buy Windows,Linux, OSX, or some other OS for your box and that's the extent of your power to choice what you want intergated into the OS. So p[eople please give it a rest because if you don't want DRM then you'll have to make your own OS.
