Difference between ultra d and ultra infinity?
jcll2002
For an ocer, what is the difference between these two mobos? (im extremely budgeted and i was wondering which one to go with)
I am stuck between these ones:
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110243
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110520
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110224
I want to get the highest stable oc possible with the x2 3800+
Thanks,
jcll2002
asus a8n-e best all around ultra board out.good o/clocks.
dfi lp ultra d best board for maxium o/clocks,setting up can be tricky,make sure you have specific hardware.
asus a8ne sets up easy,not too hardware picky,gives me 400-600mhz o/clocks with near stk voltage and good air cooling.i have the asus but if i was only interested in max o/clocks then dfi ultra would be the logical choise,but i use my computer for many things so max o/clocks is not my main mission.moderate o/clocks and stable as a rock.
unless you are going to run bh5 ram, and need high vdimm, the infinity should be just as good as the ultra d. ultra d best oc board hands down, but very picky about ram, sometimes wont boot with corsair. 1 or 2 other issues also........
The ultra D can be picky about PSU as well. When it works well, it's the best but can be a pita to get set up.
The infinitys are great boards, they don't have as many ram dividers as the lanparty boards, and don't have all those cables if that is important to you.
jcll2002 said:
sounds pretty disgusting.
it most certainly can be, but like the above guy says, when you nail it, with good psu, and ocz ram(only type that seems to works in these boards ALWAYS) it cant be beat. also, new rev boards, which have been out long enough to have flushed all the old ones out of the retail channels, fix most of these problems.
I have an ultra D and an ultra expert. I've had really good luck w/ these dfi boards. I'm running 2 gigs of corsair ram in the expert w/o any problems. But yea in terms of overclocking features get the dfi over the asus
off top
to above poster
i've had pretty good luck with the 2 ultra-d's i have owned(see sig). i have pretty close to you config but air cooled. did you find much of a difference between the ultra-d and the expert?
nope I don't really see any noticeable diff. I did the sli mod on the ultra D chipset like you too. I was building a new machine, so I bought the A8n32 and those corsair's that are supposed to match that asus board. I had a lot of problems with that board if I tried to overclock. So I returned it and got the expert. So now i'm running those asus matched corsairs in the ultra expert with no problems. hehe Other than the different board layout on the expert, which gives you more space to watercool sli cards and the chipset, I see no reason to get the expert board over the ultra d. I got 2.6ghz on the ultra D and the Expert. my chip kinda sux, so I can't go any higher.
I'd say either the Ultra D or the Infinity. I have an Ultra D and it has been great for me. I leave my computer on for weeks at a time and have no issues. Stable enough for me :).
Whats the highest stable FSB anyone has gotten on these boards? I may be in the market for one like tonight. I'm looking to hit 300mhz FSB for my Opty 165.
Kirby, you think your CPU limited or FSB limited in the speed your getting with your Opteron?
I can get 300 on my Infinity SLI/Opty 165, haven't tried any higher. All the reviews I saw had the Infinity Ultra and SLI hitting the same as each other in the 300+ range.
I'm CPU limited. My Ultra-D will do 340HTT with a lower multiplier.
Doh, guess im going to have to ditch this board and get something that will handle the super high HTT. Thanks for the input
I'm going to check out the Ultra D, Asus A8N32-SLI or the Asus A8R32-MVP...
Also, im at work and cant test, but do the Opterons let you lower your multi?
im hoping to get the opty 165 at 9x multi with 311htt on the dfi ultra infinity w/ as5+ the scythe ninja. Do you think its likely/possible?
2.8 ghz might be a bit too much, 2.5-2.7 has been the standard for the latest steppings. You might get a golden chip though.
It's possible to do 311 on the board. My chip won't let me do 311x9, but i can do 311x8 no probs. Hopefully you get a good chip.
thats a 3800+ though...hopefully the 165 will do it :D
Patriot ram works well with the Ultra-D as well. Also, get a 500+ watt OCZ power supply and that will save some headaches. I've built several DFI Lanparty systems and have not had one problem yet. I believe the ones having problems are trying to use a borderline power supply or are using ram that these boards don't like. I've used Patriot ram in each build with great success. OCZ ram is a great choice as well. Just stay away from Corsair ram (from what I hear) and you'll be fine.
I hear that too about the corsair ram, but I'm running that on my lanparty right now, @ the same fsb speed that I ran on my OCZ ram. I'm not saying corsair is better than ocz, I just haven't had any problems with my corsair modules on this dfi board. But I agree ocz ram does work very well on the dfi.
those bus speeds make me drool.....curse this crippled K8T800 pro chipset
reviving...but its pretty safe to say that the sli infinity will get 300+ htt?
Also, I dont really need sli, but I might as well keep the option open if im going to keep the option open if im going to be having this rig for 4+ years
