Difference between nForce 570 and 590?
Aelfgeft
I'm considering one of these two motherboards for my next build:
ASUS M2N32-SLI Deluxe Wireless Edition Socket AM2 NVIDIA nForce 590 SLI - $179.99
ASUS M2N-SLI Deluxe Socket AM2 NVIDIA nForce 570 SLI - $129.99
Obviously, the main differences are the wireless, the price, and the chipsets, unless one is a better OCer than the other, which I would appreciate someone noting if so.
What I want to know is, what is the real difference between the 570 and 590 chipsets? Is one more stable with OCing? Is one less buggy? Is one more customizable?
The biggest difference is the 570 has sli but in x8 and x8....the 590
is x16 and x16....Both do x16 with 1 video card but 2 cards are run differently..If it makes a difference to you then the 590 has more bandwidth using 2 video cards...
For me id be happy with 1 8800 in 1 slot running x16...two video cards like the 8800 is way to expensive for the difference in performance and all the heat you have to get rid of and thats not even talking about the power supply you would need to run an o/clocked system like this...unless for some reason that is not known to mortal man you feel the need to run 2 8800's and a 1000 watt power supply then have at it and you may want to install a small air conditioner in the side of the case too just to make sure it runs within temp limits....lol
Just kidding but all joking aside ive never seen an sli system that ran much better than 1 high end video card...unless your running very large displays sli isnt really going to do much for you.....good luck with your search.......
The differences are mostly feature related. High end boards with high end chipsets tend to get the best features. I would say that the difference in OC's probably has to do more with the individual board rather than the chipset. I'd say all things being equal, they probably OC about the same.
The main difference as noted above is the SLI configuration. If it were me, I'd just get the 570 as Asus wireless didn't work right for me on my P5W.
As others said, the difference is mostly 8 x 8 vs 16 x 16.
Supposedly, the 590 has more enthusiast overclocking features, etc... :rolleyes:
Are you SURE you're going to use SLI though?
If you can possibly live without, then a very exciting board is the Biostar TF560 A2+ as reviewed over at Anandtech at http://www.anandtech.com/mb/showdoc.aspx?i=3051.
The board looks great, performs great, and is priced very nicely!
for the record, the 8800 Ultra cant saturate 8 pci-e lanes.
The easiest example of the gross bandwidth a pci-e 16X lane is able to supply was Nvidias implimentation of Linkboost: a technology that increased pci-e lane speed 25%! a technology that did absolutly nothing to performance! a technology later revoked as "not having the performance impact we'd hoped for"
