Did my MB blow?
8man2k
DFI Lanparty NF4 SLI for a socket 939 Athlon
last night had some power issues in my area. Lost power while PC was on...a few seconds latr power went on, then off, then repeated on off for a few cycles. After the power came back completely I can no longer get my MB to POST. I opened her up, reseated everything and cleared the cmos. Even went so far as to remove CMOS battery and leave the jumper in the clear position for 30 minutes.
When i clear the CMOS and reboot the system hangs on a CMOS checksum error. And I can get into BIS setup and load default settings. After that I rebbot and get a few beeps and nothing, just hags with the HD light on and nothing going to monitor.
I was planning a rebuild anyway, but this really sucks. Any suggestions or tricks I can try? or do you think I'm f-ed?
The power surge probably killed it. One last thing to try is flash with new bios if you still can.
If you have homeowner's insurance, they might cover it. New mobo, on you insurance company, FTW! :D
as a last ditch effort, take the battery out again, disconnect all power supply connectors
from the board, then press the power button a few times to discharge any leftover charge
gl ;)
gl ;)
aye leave it overnight. Pray.
Is the bios chip soldered in ? If not you can probably get a replacement but not certain that is all that is wrong. But in general a cmos checksum error should mean the cmos programming is hosed but could be recovered. Bad news is that sometimes it means other things are wrong too. /crapshoot
Check you manual if there is a key press sequence you can hit when it is powering up to reset the cmos. /longshot.
Yes, there is still some slight hope -
I have had two boards where the BIOS chip went out on me, but
in both of those cases, I got a super fast high-pitched error beep.
EDIT: ==> Have you tried switching out your main system hard drive?
That would explain it not getting past the HDD LED action ...
A few responses:
I tried removing the battery and pressing power a few times...nothing.
Right now I'm unable to post, when I hit power i get no beeps, nothing on screen, just the HDD light on and the fans running.
New build is already on the way...it was about time anyway the system is 2.5 years old but I hate that I was forced into the rebuild....whatever
