did i move all data
frtl97
i backed up my data to external hard drive as if i was going from old comp. to new
would this also install os in hard drive,i am going to get rid of raid and would like to
reinstall all that is the old system.any suggestions would be extremely helpfull
and even more appreciated.
" backed up my data to external hard drive as if i was going from old comp to new"
-> backed up with what program?
"would this also install os in hard drive"
-> depends on what program you backed up with
"i am going to get rid of raid and would like to reinstall all that is the old system"
-> that contradicts your second question...do you want to install the OS fresh, or use the backup?
iam hopefull windows and all files, this is what i dodn't as i have never done this and don't
know what all gets transfer.iam hoping it transfer everthing that was on ths computer
any guidance would surely be appricisted
Try DriveImage XML - it's free, and I just happened to do a very similar thing with it this evening. Went plenty fast, too - raid 0+1 on 15k drives (even old ones) tends to be fast ;)
during all this as i had to reinstall os,found out wd my book's are not very compatable with vista,wd defently knows about this problem,no fix yet,computer won't even boot windows with unit turned on
