Diagnostic LED's
cvfd1615
I have a DFI LanParty NF4 Ultra NON SLI.
4 Diagonstic LED's on the bottom left when I turn the computer on
The 1st LED on the left stays on while the other 3 goes off....
Graphics card fan comes on but no video goes to the monitor
I've tried both PCI-E slots.
Video card shot?
Try booting with 1 stick of memory. I can't remember what the LED diagnostics mean anymore, but you might want to check the manual. That board was very picky with memory and might need a bios update to work properly with the memory you're using. I'd guess a memory issue before a vid card going bad.
my.php
Highlighted in red is where the LED stays on at.
Have a different video card you could pull from another system and try? Or try your card in another system?
Well according to the chart you showed it has detected your graphics card correctly but has failed at the memory. Try just 1 ram stick (may have to try with a few different ones as one may be faulty).
So since the LED light is on that means that the video is fine but its not detecting my ram...
Hmmm odd....
Took the Ram out get stuck at 3 lights
Put ram back in back down to 1 light
I believe video card is shot.
I really really really really need to get this system back going
Help is greatly appreciated.
