kirbyrj said:Maybe it fixes or does away with the 4V Dimm voltage that they were having problems with?
CCUABIDExORxDIE said:they are coming out with a brand new line of Mobos. the OCparty. basically take a lanparty, strip it off its beauty, and add the BEST OF THE BEST in components, best mosfet cooling, best northbridge cooling, best everything that works awesome. and viola OCparty.
Azzkikr1337 said:DAMN IT!!!!. I just bought a brand new DFI NF4 SLI-DR MB![]()
smashp said:nForce 4 SLI X16 I bet
banGerprawN said:Yeah, I can't see a 12V P4 connector,
There's an 8pin connector right above (from our perspective) the 24pin connector, it's black. As for the molex, you don't need it when you have an 8pin connector. The floppy connector is still there too, btw (top left of the RAM slots from our perspective). The >3.2V RAM problems ARE fixed and you don't need JP17 to access it in BIOS. Supposedly the VTT problems will also be fixed...I'll only buy it if it is.banGerprawN said:Yeah, I can't see a 12V P4 connector, or a 5V Molex connector on there anywhere. Looks like TCCD/5 could be getting a sales boost....![]()
Fawkes said:Dam you DFI dam you all to hell!
No, it should be compatible with 4pin connectors + a molex (they should provide the adapter).Rhettius said:the black 8 pin power connector:
does that mean it needs a new power supply?
i dont have an 8pin plug on my PSU![]()
eastvillager said:Yeah, shame on them for making new products. I'm sure we'd all be happier if the industry was still turning out 8086 boxes.
It may very well be photochopped, but there is a real board that is identical.Kritter said:well, to me it looks photoshopped.
It is better....not that the current SLI-DR has a problem.OuTLaWzSm said:You'd think they would move re-arrange the chipset & cooler for more video card clearance. Go figure
meatfestival said:Damn, I probably would have waited for one of these too, as I'm planning on upgrading to dual core eventually.
How well do the old lanparty NF4s cope with X2s?
