DFI vs. BFG
TeeJayHoward
Limpness Supreme
I just purchased a DFI nF-4 Ultra D to replace my BFG board while it's under RMA. Which board should I use when I get the BFG board back? Can the DFI board support a 325-350Mhz FSB? I'm sure it will have better overclocking options, but is the board itself as rock-solid as my BFG board was, pre-BIOS-incident? People on newegg talk about this board being finicky with memory. Would my 4x1GB DDR500 G.Skill sticks work okay? (F1-4000USU2-2GBHZ)
yes it will work but it will run at 333.using 4 sticks will default to 333.
as far as it being as stable thats hard to say,its kinda up to you tweeking the board to get it that way.dfi lanparty boards are touchy with ram brands and settings.its not a plug and play board.you should go to dfi street and look up settings for that ram you have and see what other people are using .
personally ive never had a dfi board that was as stable as my asus or abit boards.
if you know what you are doing with ram settings then you will be able to get it stable ,if not your in for a learning experience.on the positive side the ultra d is probubly the best dfi board out.its the most mature and has a large following.you will probubly like the dfi board better than the bfg if its a good board[not defective] and you can hit apon settings that it likes.it took me 3 boards ultra d's to get one that worked flawless.something like 20% of the boards they build are less than perfect.some are lousy and defective,some are barly stable,some are pretty good and some are stellar.you never know which one you'll end up with.i got tired of the guessing game and after the expert ate my cpu with default settings dfi replaced the motherboard and i sold it to buy another cpu and put it in an asus a8n-e.the absolute best ultra board ive had.o/clocks almost as well as my ultra d and its stable as a rock.
just a note after the expert ate my cpu i got ahold of 4 other people who had expert eat their cpu's .dfi refused to do anything for us other than replace the bad board.no cpu replacement.so 5 of us filed a suit against dfi through a lawyer friend of mine i grew up with.he handles corporate law and he filed on our behalf.well low and behold dfi offered to replace our cpu's and give us a board of our choise.3 took the venus and me and my friend are waiting for am2 to come out from dfi and were going to get a lanparty am2 and a am2 cpu dual core ,all thanks to dfi.they are afraid of a class action lawsuit against them for putting out the garbage expert board.so guys if your dfi eats your cpu get a lawyer and file suit against dfi and see what happens.they knowingly put out what they knew was a bad board and they want no publicity about it.get as many people together as you can who were burned by dfi and file suit.its the only thing they listen to.they loose their arrogant attitude when you hit them with a lawyer.if i dont think the am2 dfi boards are no good ill get a venus.all of the guys who took the venus say its a good board.no expert issues,they must have fixed it as all it is is an expert with different bios and caps,and way overpriced.once i get this stuff out of dfi,im done with them.i will never buy another dfi product as long as i live.they are not trustworthy and are very arrogant about their boards.like the attitude says ,we dont build a bad board,it has to be the user,or some other piece of hardware causing your problem.very arrogant attitude.my biggest hope is they go out of business and they will treating people this way............................................
BFG is a chaintech, far more likely to get 325HTT with a DFI. 4 sticks have to be run at 2T on all NF4 boards. Kind of moot if you are overclocking anyway, but some ATi boards can do 1T with all 4 sticks but you won't be able to scale up the ram MHz.
I've got nothing against a divider. I just want to run my RAM at advertised speeds, and my CPU at near 2x advertised speeds :)
you will do much better with the dfi. check xtremesystems.org and see how many guys are using bfg motherboards. the ultra d can be modded to sli and it will handle anything you throw at it, no prob. if any board in the world will get you that kind of htt, it will be the dfi. if you manage to kill your cpu somehow, i believe this is not covered in any motherboard's warranty.
That's good to hear. The lesser of the two boards will go in an NFS, the greater in my gaming rig. I know my BFG'll hit 325 with no issues. Kyle got the BFGRNF4U he reviewed to 350Mhz.
I do so love the learning experience associated with complex hardware. :D Thanks for the long, but informative post.
The DFI isn't that picky with memory. Start with one stick and set it to the timings you want and then start adding the others. You should be ok then.
the ultra-d is one of if not the best overclocking board in the whole AMD catalogue
consistently gives more o/c headroom on memory and cpu than other s939 boards....excluding it's more expensive performance whore relatives expert & venus :)
