DFI Ultra-D memory
SoCalDJ
Heh i need to get rid of my the memory i've got in my system now. Since the only mem i've had stable in this machine is this patriot crap i guess there are mem compatbility issues with this mobo. Any ideas on what is the best combo for this board? runnin a Opty 165 OCed too, if that makes a difference :D
lookin for stability here with some good timings @ either DDR 400 or DDR 500, hell some nice OCin pc-3200 would be nice too! Just looking out for those incompatibilites if anyone has and thoughts i'd appreciate them.
What type of timings are you looking for? My Patriot memory is great TCCD stuff.
Your memory is probably capable of 2-2-2-5 timings at DDR400 (PC3200). There aren't too many memories that will get up there to DDR500 or higher and keep tight timings like that. If you can find some nice BH-5 it would work. Your best option is probably OCZ VX memory, since your DFI board can push some amazing voltages.
However, timings aren't necessarily that important. If you can push your memory to a high speed it will outweigh what the timings are at, lots of TCCD memory (including a lot of Patriot memory) can reach some pretty high speeds.
how much memory do you want. if you want 2 GB look at either Crucial Ballistix or what i have which is the OCZ PC4000 Platnuim EB ( I love the stuff).
I would recomend the OCZ first cuz i had some problems with Ballistix (got 2 out of 3 bad sticks), but the Ballistix is great for overclocking if you get some good sticks.
Cooter
the patriot i have now isn't TCCD it's some crap i got because i had fried some sticks a while back. paid like $99 for um, they're running 3-4-4-8 atm @ DDR400 but i know they woln't go any further. They're unstable at thier rated settings...even at loosened timings of 3-6-6-10. I get BSODs and ll kinds of weird stuff if i push them that hard. I'd like some good timings and i still havent decided if i wanna do 1 or 2 gigs yet, so suggestions for both would be nice. note: also i have them running at 2.9Vmem cuz they're unstable at stock voltage.
g.skill has some very nice 2g kits, 1 for $245, the other $199. DO NOT buy corsair ram for this board. also crucial ballistix ram seems to have a problem with 1 stick breaking after a few months. check xtremesystems.org, xtreme bandwidth forum. most ocz ram works fine with this board there is a nice set of tccd, ocz plat rev 2, that usually goes for around $160 or so.
If you are worried about compatibility I think that the best choice is OCZ. OCZ works quite closely with DFI, and I believe there is an OCZ guy who makes custom BIOS's for the DFI Ultra-D (704-bt or something like that).
there are ocz and g.skill techs online, a lot, at xtremesystems.org, xtremebandwidth and amd forums. 90% of the posters there are using the nf4 lanparty boards. or try dfi street, the "official" dfi tech forum. just dont disagree with anyone, or mention that you might have a small problem with your board, because they will find you, and kill you.
The DFI Ultra-D (and that whole Lanparty family) is very fickle with RAM, so much that I couldn't just buy high quality RAM and expect it to work flawlessly. Some RAM which doesn't seem that high as quality might actually work better, so I hightly suggest you match up exact models with their compatability list.
Vanilla is right about their boards by the way. They're stupidly loyal when in fact there is plenty of reasons why DFI is still second-tier and not first-tier.
Memory compatibility is improved greatly since the original bioses. I'm running the 704-bta and I have had no compatibility problems with any RAM I put in (granted no Corsair, but lots of other stuff).
So the general consensus is OCZ tho?
lol @ vanilla great just what i need MORE enemies
Good choice. I had some G.Skill TCCD in the ol' LE form a few months ago and it was great stuff.
good ram. g.skill always has good tccd. i have a set of pc4800 la laying around here somewhere, but only 2x256mb. i used them to benchmark, when i did that kind of thing.
that ram is $151 now. was it $130 yesterday?
I think newegg automatically changes it's prices depending on how many of what sells, everytime i buy something if i go back to the page it's like a dollar or two higher, so the price goes up as they sell, and down if they dont sell
Nah actually this was in the refurb bin (same place i got my mobo too >< ), it's regularlly about 151 i think.
And be sure to make a sig IMMEDIATELY and quip that you have AT LEAST a JIGAWATT psu with quadruple redundant 24 pin plugs, all 4 power plugs plugged-in, no less than 1K Amp on the 12v rail.............otherwise every phuktard and their brother will point this out to you.......OVER & OVER & OVER again (like the 1st time wasn't enough, 12 more have to chime in with useless dribble)
Other than alot of the mindless cronnies trying to increase their post count, there is alot of good info @ dfi-street.........you just have to wade through a ton of crap to find it.
LOL yea i've seen some awesome posts over there with a ton of info, learned alot when i was testin my OC in prime a while ago and had nuthin better to do :p
