***Update***
Ok, PC boots with:
SATA HD
IDE HD
PCI-E Vid Card
MOBO
DVD-RW
2x sticks of ram
CPU-Fan
PC Does NOT Boot with any combination of the above if:
A fan is connect to the case and to the PSU
A fan is not connected to the case but is connected to the PSU
A fan is connect to the case and to the Mobo
A fan is not connected to the case but is connected to the Mobo
Any type of molex adapter is connected to the PSU
I have tried all 5 mobo fan headers, 5 different fans(3pin, 4pin, speed adjustable, and non-adjustable), and I tried three 4-to-3 pin adaptors and two 4-pin Y-spliters. It simply will not boot if a case fan or molex adapter is present. Funny thing is the CPU fan has been running the whole time and is plugged into the mobo. Also even though the system does not boot everything gets power because the case fans spin. As of 2pm yesterday everything was working and the only new thing I have introduced to the system is the change to the DFI mobo from the MSI one I had. W T F Mate
End Update
Just slapped a new computer together, turn it on and nothing.
I turned it on and I get no video output, but since I don't have a PC speaker I don't have error codes either. I will say this, near the bottom left corner if you are looking at the mobo standing in a case there are four orange leds on. I don't know if this is normal or not.
DFI Lanparty Ultra-D (just openned)
retail amd opty 165 (just openned)
2x 1gb Muskin Redline
Enhance 500w psu
7900GTO
1x sata HD
1x DVD-RW
Everything but the first was working as of 2hrs ago.
Any ideas?
Ok, PC boots with:
SATA HD
IDE HD
PCI-E Vid Card
MOBO
DVD-RW
2x sticks of ram
CPU-Fan
End Update
Enhance 500w psu
7900GTO
1x sata HD
1x DVD-RW
Any ideas?
