- Aug 29, 2004
uOpt said:I also had very heavy instability overclocking my SLI-DR, corrupting two OS installs. While there is no guarantee that the PSU caused it, and that there was some funky BH-5 involved that I didn't use before, I do the same kind of overclocking all the time and didn't have that kind of supercrash anytime before or after using the Athena.
When using a DFI baord the first thing one should looks at for the problem should be the motherboard/RAM. DFI makes boards that violate spec....which is why overclockers like them....but the spec's exist for a reason....so this is also why you see so many problems with DFI boards and DFI boards not working with other spec compliant hardware.
