Ok, alot of people are having problems with there DFI nforce4 boards and i know of a problem alot of people have and dont know it. Here is the problem:
Some PSUs have thicker than normal wires, like the X-connect psu or the OCZ mod stream.....as a result of this, when some people are plugging in the 12v 4-pin wire to the connector, they are accidently bending the resistor thats right next to the 12v 4-pin connector. If this gets bent as a result of the wire being too thick, it will cause instability or make a system not post at all. A great indication that this is the problem is by looking at the red led lights in the left hand corner. if 3 of 4 are lit and you arent getting a post, only beeps, this is your problem. Others have just stability problems as a result. I have already helped 4 people with this problem and they didnt even know that this was there problem. Most dont and end up blamming there memory or PSUs or the CPU, ect. So , if you have a premodded PSU or modded it yourself, or even if your wires are thicker than norm and you are having stablity problems or no post at all, there is a good chance this is your problem. I had this problem and i shaved the rubber grip down to normal size on my Ultra X-connect PSU 12v 4-pin wire and bent the resistor back into place, and never had a problem again. After i helped the 4th person, i had to post this as im sure there are others who have no clue why there DFI Nforce4 system isnt working or is unstable. Good luck.
