DFI NF4 infinity sli
jcll2002
I was wondering if this board is a good choice for my new rig that will have an opty 165, pc4000 ram, a 7900gt (maybe 2) ect. The thing is, all this dfi being incompatable with high end psus and ram is scaring me.
Will I have a problem with this motherboard if I use an ocz 520w powerstream, enermax 535w, or enermax 500w liberty psu?
Also, I read a review that it doesnt have an LDT voltage option. Will this affect my ability to overclock the opty? I want to be able to get the best performance.
Thanks,
jcll2002
EDIT: before the info regarding physics came out, I was pretty sure I wasnt going to go sli. Thus, i was set on the ultra infinity mobo. Now, im not so sure. Should I just get a sli mobo just incase? Or should i go with the regular pcie x1 and just get a ppu card if i really want to? AHH!, so many decisions
I use a 520w powerstream on an Expert and have never had a problem or experienced the cold boot issue. It seems the supplies around 600w+ are causing this problem. If you go the DFI route just make sure you buy some ram on their recommended list. The G. Skill pc4000 is pretty cheap right now and will take you to 2.25ghz with no divider @ 250mhz fsb.
Ya, the whole PPU has messed alot of stuff up. It seems upgrading is sketchy right now... I probably won't buy a PPU until am2 is stable or some game worth playing sports the technology.
I personally would shy away from the infinitys.
they have a lot of problems with ram, and hate ide stuff.
I personally have an infinity nf4, and it is the bane of my life right now. and dfi refused to admit that it was a bad board. they just said, oh, your stuff is just incompatible....yeah, sure...whatever.
it hates my ram and my ide hardrive and ide burner.
my hardrive is forced to run in pio mode, or it will error the crap out of everything.
my burner is forced to run in a slower ata speed than it is capable of.
and for my ram, I have to undervolt it, lower the driving strenght, lower it to ddr 333, and increase all of the latencies, otherwise it corrupts all of my data. which combined with the sketchy hardrive situation, I've had 3 corrupted and unfixeable windows installs.
the ram, hardrive and, burner have all 3 been used in 3 other mobos and worked awesomely. a shuttle ak32a socket A mobo, an expo 9nda3 939 mobo, and an albatron k8-sli 939 mobo.
both the ide and ram situations are a common problem iif you google about problems with infinitys.
if you are looking for cheap sli, I'd get the jetway 939 sli, or the albatron k8-sli.
despite less than stellar reviews of the k8-sli, I had one, its the best A64 mobo I've ever used, stable as hell, fast, overclocks like a mofo, I wish I wouldn't have sold it to a friend in a custom build i did for him. but I wanted him to have reliable hardware, cuz I have had tons of bad hardware just in the last two years. every video card I've ever purchased, besids my current, has had to be rma'd for DOA, or premature failure. and I've had 2 premauture death mobos, and this infinity, which is a piece of crap. it overclocks nice, as seen in my sig, but, I can't actually use it...
hmmm...But I wont be using ide, itll be sata + ocz ram. AHH this is scaring me! Should I just go ultra d? How hard is it to mod to sli?
Maybe look at an Abit KN8 SLI? It's around the same price and doesn't have quite as many issues as the Infinity series (although there are a few..be warned).
I had no idea that they had so many problems. Should I just go with the sli d? I need a board that will do 300+ htt.
Check the sig...I've had it running for about 6 months now without ANY issues...great mobo IMO. Basically the same as the Lanparty series without the flare...
you will be using an ide cd or dvd drive though (unless you have that one sata drive). my cd burns don't pass file verification in nero with this mobo, though they seem to work ok usually.
that looks like a good option. Is this board for a first time builder who wants to overclock (300+ htt)? Also, what about the an8 sli?
Alright here are the ones Im looking at
http://www.newegg.com/Product/Product.asp?Item=N82E16813123246
http://www.newegg.com/Product/Product.asp?Item=N82E16813136164 (though scared)
http://www.newegg.com/Product/Product.asp?Item=N82E16813127225
Thanks
The J and + are the same board with just the "feature" chips soldered on or not. They will clock the same. You'll note even in the pictures, CPU-Z picked it up as the + board even though it was the J.
If all your looking for is the pretty splash screen then this is true.
The Ultra-D is great, modding to SLI is supposed to be quite easy but then you would need to buy an SLI bridge, which would cost the same if you bumped up to the SLI version of the board (I believe).
well, I think i just decided not to go sli. 1) i only use a 7900gt atm, maybe another when the physics gets more in-depth 2) ill be changing the mobo in a while for quad core.
So, i think the dfi ultra d is my best choice due to oc ability, moddable ability.
Also, to mod it, it only costs $15 for the bridge (i think)
300+ HTT= Ultra-D and it can be modded to sli down the road. It is also less picky about components. Good luck with whatever you chose there are lots of options...
