DFI motherboards... confused!
doanster
If the Infinity series is the entry level models, then what's the difference between the Lanparty and Lanparty UT series??
The UT doesn't have all the goodies (FrontX, PC Transpo etc.)
infinity does not have uv jive, and the bios is slightly limited compared to the lanparty series.
lanparty ut has fancy looking mainboard and overclocking bios.
lanparty has fancy board, front panel thing (front-x) and a carrying rig for your pc, and overclocking bios.
the infinity bios has a few less ram timings, and some of the voltage adjusting options dont go as high as the lanparty/lanparty ut. but unless you are using bh/ch/vx ram, the infinity boards should do it for you. except if you have a thing about uv dimm/pci slots.
I've used both Infinity models and Lanparty and they both worked fine. At this point, I'd probably just get the infinity since it is cheaper unless you need the extreme voltages of the Lanparty.
