DFI Motherboard Question
AVAFREAK182
OK so I just got this DFI LP NF3 Socket 754 mobo.
I have my Zalman hooked up to it on an Athlon 64 3200+ Venice.
And there is a setting in the BIOS that says:
CPUFan on if CPU Temp > 25-75
CPUFan off if CPU Temp< 25-75
And the fan changes in speed, and sometimes just shuts off, which is hard on the fan, and I am overclocking, so I need the fan to be on full blown all the time. Does anyone know what gives?
there should be some settings in the BIOS called SmartFan or something similar to that, disable that and your fans should run at 100% all the time.
Well just go to the section in your BIOS where is monitors RPMs and temps from your mobo and you should see something similar just look through all the options, on my DFI board it's SmartFan that's why I thought it would be the same as yours, just look around.
yeah I did and this is ALL it has
