DFI Lanparty UT SLI-DR Expert?
DangerIsGo
Anyone know when this board is expected to come out? I want to get it for the wider room between the PCIe slots and DFI's great OCing. I wanna put some aftermarket coolers on my GTX's but cant fit in a regular DFI board. And does anyone know how much its going to retail for?
Some places show it coming instock around October 17th but some on xtremesystems.org have said one of the guys that work at DFI told them it would be delayed a month for some unknown reason. There are a few places taking pre-orders but not sure on the exact date. I have one already pre-ordered but not really expecting it anytime.
kirbyrj said:
What's the difference? 2x16 lanes for SLI?
nope, just a refresh of the board. no jumper needed for 3.2-4v vdimm, bios controlled sli switch.. other tweaks like that
wider slots between the pci-e slots, which will allow for much better cooling, and chipset cooling, which are both a thumbs up. Too bad its delayed until mid November. and the thing im baffled by is the lack of the molex and floppy drive connectors on the board. i guess they are taking the 5v from the 24pin connector.
The reason I want to get it is cuase of the wider slots and the great OC that DFI is known for. I wanna put better cooling on my GTX's and I cant do that with a regular DFI board. Also, the board has a floppy connection, its parallel with the boards edge beneath the IDE connections.
I never saw it on the board! i thought it was just missing. You may be in luck for finding better cooling for your GTX's, as consumer9000 and stasis are putting out some new 7800gtx hsf's, that *might* fit into SLI in a regular spaced board.
i wanted one but i really couldnt wait 3 months for a board... i know imma regret it one day
I guess I just don't understand what the appeal for DFI motherboards is. I bought my NF4 Ultra-D on the recommendations of a lot of people, only to find it was an unforgiving bitch to set up. Just tonight, I found out that I can't use my second stick of RAM because the 3rd and 4th RAM slots are broken. I normally wouldn't hold it against DFI, but I searched the net and found enough other people with the exact same problem for me to be pretty fucking pissed off that I now have to spend $20 to RMA the motherboard in an attempt to maybe, possibly fix a manufacturer defect.
DFI's great if you want to spend more time benchmarking than you do playing games or actually using your computer, but who enjoys Googling random forums to find out what impossibly complex settings you need to use in order to get your system to boot into Windows?
Ah, indeed, this is the truth. DFI boards are for the true geeks of the world. The ones who, instead of spending their Saturday nights at a party, or at the movies, or enjoying fine wine and awesome steak like the one from the Matrix, they instead prefer to tweak their board until it is finally stable enough for them to enter the closest forum their saliva-coated keyboard will allow them to, and post a result from A)3d Mark 01, B) 3d Mark 03, C) 3d Mark 05, or C) SuperPI 1M with a heading that generally follows a format such as "OMFG! NEW WR FOR *insert benchmark here* WITH DFI!! FOR TEH WIN!!".
Often, no reply is heard from the person after their initial post and placement of pictures/validation, as the board has, again, decided that a reboot will invalidate anything that was previously thought possible. "Oh, and by the way, " it says in it's carefully neutral computer-speaker driven voice. "I just thought I'd overvolt your FX-57 by about 83.4%, because you didn't spend enough time swapping the bajillion and 3 BIOSes to find that special one that strokes me and all my components the right way. Have a nice day."
...or it's for people like myself, who want to get the best overclock possible out of their 3200+ and VX RAM to play 3d games.
Just because it's used by Macci and OPPainter and all those guys doesn't mean it's no good for you and me.
Agreed. Maybe there are people that wanna get more outta their CPU and RAM like me but the Asus board can only go so far. I dont post crap like that. Im im happy with my system, then so be it. But I dont go around posting things like OMFG! NEW WR FOR *insert benchmark here* WITH DFI!! FOR TEH WIN!!".
this board will be using an 8-pin 12v connector as opposed to the 4-pin on the previous version. this is why there are fewer power connectors.
thanks for the info, looks like the Fortron bluestorm wont be a great PSU for it then. ohh well, i really dont need the Expert anyway.
Newegg is selling a thermaltake set that allows you to go from 20-24 pin connections and from a 4 pin to 8 pin connections. Here is the link. Im gonna get it once i get the expert.
Jeez, dude. It was a joke. All I've got here is DFIs, with the exception of an Abit AN8. Do you want me to add smilies or something? Dont go tight over it.
No im not getting mad at all. im just saying that im not one of them benchmark freaks...I just wanna get the most outta my core and RAM. I dont sit there and 'play' 3dmark05 for hours on end.
