DFI lanparty ut nf4 ultra d problem
dragon
Problems with this since I put it in 1st some bad geil ram was causing bsods and preventing windows install, now I have different ram in and it is working.
Anyway, marvall ethernet port is not detected and neither is firewire in windows xp pro.
Bios settings can not be changed, I can change them but if I do it will give me a black screen when it restarts. I have the latest bios flashed. I believe I will just reflash to older bios to fix this because it was working before I flashed it with the newest, unless someone has a suggestion.
I had that board a couple weeks ago when I decided to try the A64 scene but I've since then returned everything and went back to my good 'ol P4 stuff thats ALOT easier to O/C no thanks to its BIOS simplicity unlike that A64 which was a royal PITA to figure out.
but, to get back to your question. while I cannot directly answer the question(s) to your problem, maybe you could start a thread at the DFI Steet Forum and see what they'd have to say.
it might be worth a shot. good luck. :)
I'm just taking a stab at this because i dont have the board yet.. i'm asuming you have the latest chipset drivers in, sometimes with extra ethernets they have specific drivers for the device cuz they are not in the chipset drivers, i dont know if this is the case with the dfi board but if it is they should be downloadable from dfi, they wouldn't necessarly be detected before you installed the drivers for them, i had an asus board that did this
If the ethernet worked in the old BIOS go back to it. Since you have problems with both the Firewire and Ethernet, I'd assume it was a BIOS problem. Since you can't save changes to your BIOS, I don't know what to tell you :). Flash back to an older one I guess.
Hi, everyone that offered sugestions. Thank you all. I re flashed bios to 1-25 release and all ports are showing up and I can change stuff in bios and it saves.
