DFI Hybrid (P45 + ION)
I'm a little lost on how the two share video. Isn't P45 non-integrated graphics? Apart from that, looks interesting! Price is a little bit high, but reasonable considering that it's really two platforms.
It's 2 separate computers/os running on one board. They are Nativity connected internally with a Gb connection. So you can share video between the two hard drives (computer/os) over a logical Gb connection. For the P45 system I'm guessing you need to use a graphics card. I don't understand the DVI connection on the motherboard for that either.
I can see someone running a Linux box on the ION platform and Windows on the p45, then with a button click swap between the two. I also think it would be cool if you could have two displays hooked up and be running both at the same time without having to swap back and forth.
I can see how this can save power. Logically, I can build two C2D/P45 systems for the same price as this board. Maybe I just don't care about my power bill or just plain power-hungry. I do have two Core i7 systems running 24/7, haha.
Or maybe just have fear of small e-peen. I'm just gonna go with that :p
It's too bad they couldn't build a system like this, with a soft-transition, where an Atom kicks in after boot up for daily tasks, and you could somehow power up a higher end Intel chip once the OS detects a high load app starting. Almost like load-balancing between SLI or even more so Hybri-SLI or Crossfire, I forget which company was doing the On-Board w/ PCI-E bridging. Anyway, cool stuff, not sure I could find use for it.
Just seems like an overcomplicated form of Speedstep/Cool&Quiet
This is the first step.
From the video, it appears there are two dvi connectors on the board. One for connecting your dedicated graphics card from the P45 side, and one output dvi. The output dvi goes to your monitor. The output dvi is hardware switch selectable between your P45 graphics card passthrough and the ion gpu.
Very cool!
Would you need 2 windows licenses I wonder?
EDIT: $399?!? Jebus! You could buy one of those sub $200 netbooks and strap it inside your case, plus a regular mobo for that price haha
I'd buy one if it was more reasonably priced...even $250 or so. $399 is insane. You literally can strap a netbook inside your motherboard for cheaper than that. A P45 board is $100!
This doesn't do anything well.
Thats it's problem.
COOL piece of technology, but worthless otherwise.
Well I could find a use for it I'm sure. The one use I was thinking of was having both my PfSense router and my file/media server in one box. I think that'd be really nice and it'd clean up my media/data closet nicely as the gigantor full tower cases I have are a bit overkill and all my drives are external USB, Firewire or eSATA anyways.
why not just VM the router?
Because, other than some *nix action on my main box, I'm a VM newb. I haven't the slightest idea about how to go about that.
Xen makes (seems to be default from most distros) virtual bridges for each interface, ie if you have a 4-port NIC it will make virbr0, virbr1, 2, 3, they correspond to eth0, eth1, eth2, eth3
in the Xen guest VM config file for the router you just give the VM those interfaces as you want them, the guest doesn't know the difference once it's up.
VirtualBox and Qemu are a bit different but still workable.
If you're interested in trying it out, let me know, I'll give you my IM contact info and you can pester me to your heart's content.
I would say its worth $300 to look at a couple tutorials :p
He's trying it out (we're talking via PM).
I forgot to mention, in Xen if you have VT-d (check your chipset) and start the guest as an HVM, you can pass a whole PCI card to the guest. So you can pick up a 4-port 10/100 card for $25 and hand the whole thing to a Xen guest instead of mucking with the virtual bridges. :D
Don't the new macbooks do that?
